Toshiba e-studio 25 showing drum life warning sign
  • ttean
    • Oct 2010
    • 32
    Toshiba e-studio 25 display shows drum life warning.
    I have replaced a new drum in the process unit and it still shows drum life warning in the display. Can the drum life warning be reset by going into service mode or do I have to replaced a new process unit.
    Thanks.
    ttean
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    If the firmware is high enough then yes it can be reset via service mode. If not then change the pico fuse in the process unit and it will reset.
    • ttean
      • Oct 2010
      • 32
      Hi Mr. Spock,
      I cant find the pico fuse in the processing unit for e-studio 25. Can you advise me exactly where the pico fuse is located.
      Thanks,
      ttean
      • emujo
        • Jun 2009
        • 3009
        If 08-689 is set to a "1", then 08 673 will reset the values stored in 08-355/401. Been a while since I looked, but I believe there was a firmware update that needed to be applied before 08-673 would work. Give it a try and if the message does not go away, set 08-355 and 401 to "0". Emujo
        • Harry
          • 228
          The pico fuse is a 77 ohm thermale fuse that blows the first time when you put in Drum in the mfp.It is located one the Led assy inside
          the Drum assy. Just look for a blown resitant one the Led assy and change it with the same on.
          Harry
          • emujo
            • Jun 2009
            • 3009
            You know I may be wrong (and I am never wrong, just ask my wife), but I don't remember any fuse on the process unit. You have to reset through 08 mode. You should be using a PU1600S (PU1600C if firmware was never updated) or replacing individual drum and developer and resetting the counters. Besides, if the process unit is fused, why would you need to reset the thing in service mode? Emujo
            • Mr Spock
              • Aug 2006
              • 2064
              The original units had a fuse under the top rear cover so the customer could replace them and have them reset. Then they made the field serviceable ones that were reset via service mode so the dealers could make a little more money. This required an update to the firmware and the 08-689 code to be set accordingly. Even with the updated firmware you could still use the fuse to reset the code you just need 08-689 set to customer mode.
              The full unit (if I remember the numbers correctly) was $425 and the rebuild kits came to $225. Now if it was your wallet which way would you go??
              • emujo
                • Jun 2009
                • 3009
                I would replace the drum,and developer and charge the cust $425 and say my name is "spock, just spock". BTW, I'm in the shop and making the "big" bucks!!! BTW/BTW thanks for jogging my memory on this, I now remember the customer ordering the PUs and us having to go out there anyway because they couldn't replace the damm thing on their own anyway!!!BTW/BTW/BTW...one more post to get to the 1K level for you...gonna throw a party? BTW/BTW/BTW/BTW Anyway, to help out Ttean with original post....since CRUs are no longer available it looks like he has a SRU in a non upgraded E25. The SRU's probably wont have a fuse (not needed since the firmware upgrade was mandentory) and until firmware is upgraded will continue to show the drum life message. Make sense to you? Emujo
                • Mr Spock
                  • Aug 2006
                  • 2064
                  I was not even looking at my post count like some of the other post whores do... I wish I was told about the shop I would have come over and explained it in person!!!!
                  • Harry
                    • 228
                    Last one all Pcu Cru ore Sru has that thing one it! if you change an SRU one a not Firmware updatet Mfp it reset the counter anyway! The Mfp Displays Drum Mantanance hafe to reset Counter 08-6-- not remember If Display indicate change Drum there is an old Firmware in The MFp and the only way is update Firmware or change the risistor on LED assy see Servicemanual difference from old or new CRU . There was another thing but with this one on the functionsettings you lost every counter!
                    Reguards Harry
                    PS it is not a Fuse its a resistor-FUSE for you Emujo
                    • waqas_pk
                      • 18
                      i am a small thing in front of all you technitions but i know the problem of emoju because i already had suffered from this problem but at last i got the solution that you can say that it was simple but solved my big problem. so the proccess is
                      Turn power to “Off”
                      Press and hold the “0” and the “8” buttons
                      Enter “673” and press “start” ( this will reset 08-355 - display of drum life counter and 08-401-drum life counter ) -- valid when08-689 is set to “1”
                      Enter “0” for the value
                      Press set to save value
                      If Drum Maintenance Warning message does not disappear from display after ensuring 08-689 is set to “1” and performing 08-673 then perform the following:
                      Press the “Program” button on Operation Panel
                      *, #, *, * (puts into service mode)
                      Select “Test Mode”
                      Press “Set”
                      Select “Maintenance”
                      Press “Set”
                      Select “Memory Write”
                      Press “Set”
                      Input the Address “ *425762”—(display will look like E25762)
                      Press “Set”
                      Input Data-- set to “00”
                      Press “Set”
                      Change address E25762 to E25763
                      Press “Set”
                      Input Data—set to “00”
                      Press “Set”
                      Do same for E25764 and E25765—Set data to “00” for them as well
                      Cycle power off then on
                      • jamesyboy
                        toner monkey
                        • Jul 2010
                        • 188
                        cant remember the code but its all to due with resetting the drive counts you get that if you have to ram clear then you have to clesr drive count all a long time ago got a manual somewhere
