E-studio 232
  • Alan Aya
    E-studio 232
    Have this problem with one Toshiba E-studio 232, it show "wait warming up" and never come to Ready, power it On & Off a few times only it can come to Ready. If you off the machine and then on it again, it show "wait warming up" and you have to On/Off it a few times to get it into the ready mode.Suspected fuser problem, did replaced the fuser unit from a different machine (good condition),Hard Disk,System Logic but the problem still persist. What could be the cause? Anybody have the solution for this problem?
    Regards
    Alan Aya
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
    Paul@justmanuals.com
    • ivovb
      • 695
      Check memory module.
      Check cabling between fuser and pcb.
      HDD - did You take such of a macine with the same ver of firmware like deffective one?
      BR
      I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
      • randandrawson
        • Oct 2010
        • 21
        not toshiba specific, but check the AC connections between the fuser and the engine. Junk in them, or misalignment, bad contact, etc. Sure sign of intermittent warm up problem.
        Sounds like the temp limit switch, but we assume your "known good" fuser is good.
        • Paper_path
          • Jul 2009
          • 55
          A bad power supply. Low 5v line usually.
          • digivision
            • Aug 2009
            • 44
            hi dear, U have to format HDD N see, After that u can Update The FW, TC bye
