Toshiba estudio 351c make sharper and clera copies????
  • omns23
    I have a toshiba 351c making clear copies but sharper and low quality copies in black and colors copiers anybody have idea ?
    how ti fix?
    have any code? to adjust the toner
  • randandrawson
    • Oct 2010
    • 21
    not understanding your question?
    • tinnyjay
      • Oct 2009
      • 663
      how ti fix?
      3.2 Adjustment of the Auto-Toner Sensor When the developer material is replaced, adjust the auto-toner sensor in the following procedure. (1) Install the cleaner and developer unit. Note: Do not install the toner cartridge. (2) While pressing [0] and [5] simultaneously, turn the power ON. The following message will be displayed. 100% A A3 TEST MODE [0] [5] [POWER] → (3) Key in a code and press the [START] button. Code 200: All developer materials 201: Developer material Y 202: Developer material M 203: Developer material C 204: Developer material K 206: Developer material Y, M, C
      this is from SM
      "Who loves the roses,must also bear thumbs"
      • Mr Spock
        Vulcan Inventor of Death
        • Aug 2006
        • 2064
        If it prints good from a pc then it is the optics need to be checked/cleaned/adjusted.
        If not then it may need service to clean the laser, replace the developers, or 100 other issues with the machine.
        • ToshibaTech
          • Apr 2007
          • 580
          If you are saying that your black copies are better looking than the color copies that is pretty normal for these. The color quality is not all that great on a multi pass machine generally speaking. These are basically a "black and white machine that can do color" or a "business color machine."
          I will not give you service manuals or firmware.
          • digivision
            • Aug 2009
            • 44
            HI dear, I have service manuals for all the estudio models. ill give u @any time,
            Tc, Bye, Contact me on +94 772248606
            • bellsysjoe
              • 12
              you can call me I am a tech 704-562-1543 can help you
              • ToshibaTech
                • Apr 2007
                • 580
                Well at least you did ask for it!
                • jamesyboy
                  toner monkey
                  • Jul 2010
                  • 188
                  a clean machine is a mean machine!
                  these machines are good if looked after well,clean optics!,remove and clean laser ,clean and apply conductive grease to the revolver bias terminal,run iqc 08-396 calibrate it properly 05 4 fax 1642,70 fax 1008
