Toshiba e-studio 25 duplex jam
  • CTH
    • May 2025
    [Jamming] Toshiba e-studio 25 duplex jam
    I have a strange problem with this copier. It randomly jams paper in the duplex unit. The 2 paper sensors from the duplex are OK and the paper is not blocked by anything. The paper doesn't always stop in the same position. It never jams on single sided paper.
  • ivovb
    • 695
    Try to set 08-685-1. It will slows productivity (ppm) in duplex but resolves the problem.
    BR
    I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
    • CTH
      Did that. The problem was not solved. It blocked from the first copy.
      I did all the checks from the service manual regarding jams in the adu. All is fine.
      • bryand
        • 92
        Is the jam code E08? There was a bulletin for this jam, you will see 2 ridges on either side of the clear guide near the top. These are for pressure of that guide against the duplexor. You had to remove 2 or 3 mm with a knife on the rear side of the ridges allowing more pressure to be applied to the paper.
        • ivovb
          • 695
          Yep, this is the hardware solution for the problem. I have give the easier one - software. But it seems that culprit is somewhere else. What about wiring between GH-1030 and duplex?
          BR
          • CTH
            Thank you for the solution. I'll take a look first thing in the morning and let you know.
            • mcprest
              • Sep 2010
              • 19
              Still not working. But i have seen another problem: now the paper is jam before the registration roller. And sometime when i start the copier appears "Call service" with no code error. And sometime while is running it's restarting himself. I think is crazy
              • ivovb
                • 695
                While the error message or “Call for service” symbol is flashing, pressing the [CLEAR/STOP] key and
                the [8] key on the digital keys at the same time shows one of the following error codes on the copyquantity
                indicator as long as those keys are pressed.
                Concerning restarting - smells like pressed/twisted cable or main board.
                BR
                • ss12
                  • 289
                  you may want try replacing the motors in the duplex ,ive had problems with these before.
                  • CTH
                    Hello,
                    Thank you for all your replies. So far the problem has changed. It is now jamming in the registration roller. I saw an interesting aspect: the copier door is deformed. If I press onto the left side of the door, the jamming stops. Can this cause the jam in the duplex also? And can this cause another strange problem with this machine: sometimes there is no image on the paper?
