e-studio 65 popping 4amp fuse
  • T911
    • Jun 2007
    • 628
    had broken dev stuff. replaced developer bearings and gears now the machine is popping a 4amp fuse on the power pcb. replaced the fuse and machine will work for a few copies and then pop it again. checked developer unit again for any drag but spins freely. anyone come across this before. thanks T
  • just a tech
    • Jan 2007
    • 332
    had that problem a couple of times in past..when i had that problem, i was also getting a message on display screen saying "close front door"..problem was that when the dv. unit had stopped turning, the toner supply auger got compacted in auger assembly and the bottom of toner hopper which effectively locked up the augers and also caused the spring loaded gear at the end of the toner supply auger to come disengaged.( where the hopper and supply auger meet )..after unblocking and freeing up all augers from the toner hopper to the dv. unit, fuse didn't blow and all was fine..hope this helps..
    • T911
      • Jun 2007
      • 628
      thank you. i'll look into that area. T
      • just a tech
        • Jan 2007
        • 332
        welcome..let me know what ya find..ya got my curiousity up..lol
