gmail with estudio 3500c
  • digicor
    • Jul 2008
    • 1158
    I have been having trouble with the estuduio 3500c e mailing with gmail,, is there something special im suopposed to do with it? ssl, ttl, port 25 is default,un pw are gmail related, any ideas?
    thanks
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    You need to set the gmail account to relay (search for outlook express setup instructions) Follow these and you should be good to go. Also use the ssl port (485 I think).
    • TheOwl
      • Nov 2008
      • 1732
      Maybe this will also help.
      Configuring other mail clients - Gmail Help
        • 8207
        Do a search of the Toshiba forum. There are several in depth discussions on how to successfully Scan to Email via Gmail. 1st hint, Port 25 will never work.
        I suggest you create your own house Gmail account for the Service Dept and apply it to your customers. Of course, this means to your savy customers that you can read their emails, not that you want to. It is the customers responsibility to contact their ISP and create their own unique email account.
        Or you can create a Gmail account "on the fly" for the customers location and forget the passwords. Not hard to forget, there are so many.
        Xerox On Site Tech support will not configure this. They will say it is not covered under Professional Services and it is up to the customers IT provider to create scan to email. Billable labour for Xerox, of course.
        • digicor
          • Jul 2008
          • 1158
          i searched the forum and found many usefull information, but the port 25 was said to work, i had it hit the relay and be rejected because of authentication, could not authenticate, was the error message, i try the port 485 see what happens, thanks for the info
          • digicor
            • Jul 2008
            • 1158
            thanks for the information.
            • ToshibaTech
              • Apr 2007
              • 580
              Gmail:
              SSL Start TLS, Accept all without CA
              smtp.gmail.com
              username@gmail.com
              password
              login or auto
              NO pop before
              port 587
              don't forget to put DNS servers in or just ping smtp.gmail.com and use that ip without DNS.
              I will not give you service manuals or firmware.
              • digicor
                • Jul 2008
                • 1158
                thanks for the info it sounds very helpfull.
