Z Fold on any current Toshiba copier
    • 8197
    I know there is no accessory from Toshiba to allow automated Z folding on the current line of products. I know there is only the Saddle Stitch option.
    I know you can buy 3rd party Folding machines that can do Z fold.
    Any idea how we could automate the process on a current colour copier. Current colour copiers have no optional Post process insertor.
    Do you think it would be possible to use the insert feature found in the Print driver under the Paper Handling tab to pull preprinted pre Z folded documents from the Bypass?
    • 23008
    I'm not a Toshiba guy, but I can't see that working. Pre Z-folded paper won't pass through the machine. If it does get as far as the fuser, the upper claws will snag it up. =^..^=
      • 8197
      I will have to get some preprinted Z folded samples and run it through the copier at my office.
      You are probably right as I am sure all competitive copiers with a Z fold option place this device after the fuser.
