e-Studio 520 Transport Belt/Blade
  • MFPTech
    • 486
    What are the part numbers and life-cycle for e-Studio 520 Transport Belt/Blade, please?
    Is there any code in 05 or 08 mode I should execute, please?
    Thanks!
  • sdrawkcab
    Confused & Bewildered
    • Jun 2009
    • 317
    Belt 6LA2306500
    Blade 6LH72622000
    Roller 6LA23070000
    Reset counter through PM Support mode, 6 and start
    Some days, it's just not worth chewing through the restraints
    • MFPTech
      • 486
      Thank you very much for your help!
      Is PM Support mode the same as 08 Mode, please?
      Cheers,
      • sdrawkcab
        • Jun 2009
        • 317
        PM Support mode is where the life counters are for all the consumable parts i.e. drums devs fuser part etc, it will tell you what parts need changing, and you can reset the counters as you change parts.
        Hold down 6 and start and turn on copier, wait for the beep and then enter 2, the rest you will follow.
        BTW the life of the transport belt is 450k.
