toshiba 650 showing error code CF80
  • Techace
    • 35
    hi,
    i have one machine toshiba and its showing error code CF 80. i have no idea what is this code. can any one help me to sort it out.
    thanks
  • bojans
    • 1313
    This is from documentation>
    Hopper motor lockup: The hopper motor does not run
    normally when the power is ON or the copying is started.
    [CF80] Hopper motor lockup
    (1) Check if the recycle toner transport motor is not locked (no extraneous material or toner clod in
    both the toner transport sections at the recycle toner unit).
    (2) Is the disconnected?
    (3) Check if the connector of the LGC board and connector Pins are not disconnected.
    (4) Replace the hopper motor.
    (5) Replace the LGC board.
    • Techace
      • 35
      Thanks bojans,
      i will definately do as you say and let you know about it. i hope its gonna work.
      Thanks and thanks alot.
