Toshiba E-Studio 650 CD1 Error Code
  • tinnyjay
    • Oct 2009
    • 663
    Hello
    I have changed motor brush,drum unit,developer unit,transfer belt unit,recycle motors,sensors and still CD1 is appearing.
    Any experienced guy with this code,can help me?
    I have service handbook and i know what does this code.
    "Who loves the roses,must also bear thumbs"
  • Toshi
    Check the copper contact plate that touches the drum brush on the back of the drum unit, make sure its not dirty or bent.
    • ivovb
      • 695
      Check/clean/exchange recycle toner transport tract - there might be collected toner clod. Replace LGC board.
      BR
      I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
      • Meach
        • Nov 2008
        • 128
        CD-1 CD-2 error bulletin
        • tech07
          • Aug 2008
          • 410
          I,ve had several cd1 codes caused by clogged used toner unit..
          • michaelc
            Field Tech
            • Mar 2011
            • 590
            I add a couple of cable ties in the recycled toner unit to help break up the toner more
            It didn't say that I couldn't do it in the manual.
            • beatbrother
              • Feb 2011
              • 24
              Re: Toshiba E-Studio 650 CD1 Error Code
              I had a CD1 once and turned out was the waste toner bottle, It was totally FULL!!
              Did u make sure is already empty and that the toner auger from the steering worm is rotating??
              by the way: I hate E-650 Lol
              • michaelc
                Field Tech
                • Mar 2011
                • 590
                recylced toner comes from the drum cleaning station, waste toner comes from the transfer leaning station? Or thats what i thought. I have been wrong before.
                Before manuals4you gets me again, I have just realised the post date. Look before you leap ? I tend to look up on the way down somtimes.
                • beatbrother
                  • Feb 2011
                  • 24
                  Well that's how I figured out.
                  Make sure the waste toner bottle is empty.
                  I believe that machine doesn t not recycle toner but put it in the waste toner bottle. transfer belt unit does store toner in itself
                  Greetings Michaelc
                  • emujo
                    • Jun 2009
                    • 3009
                    Toner from the drum is recycled, toner from X-fer belt is waste. MFP needs f/w update to take advantage of the new(er) codes to help resolve the CD1 codes..This is a pretty old box, might be a logic bd problem. PS to TinnyJay..still waiting explanation of "He who loves roses...." quote. Emujo
                    • bauer
                      • 72
                      BEATBROTHER -I can see why you would hate the 650, They DO recycle toner & the transfer belt does not store toner, the waste toner is augered out to the waste toner bottle
                      • beatbrother
                        • Feb 2011
                        • 24
                        Lol it's all clear now that explains a lot! ha ha ha
