Toshiba estudio 850 error sf-70
  • Dimpo
    • Aug 2009
    • 104
    Hi
    Does someone know how to clear error sf-70?The manual is saying it might be the toner transport motor or the board so i dont know which one to replace and my customer is warried because he his afraid that after buying the motor the problem will still require the body then after buying board still the problem remains,So is there any way of clearing the error after putting new parts?Please help
    Best Regards
    Dimpo
  • ivovb
    • 695
    Did You check Toshiba's procedure?:
    [CF70] New toner transport motor abnormality
    (1) Check if the transport auger and paddle are not locked (no extraneous material or toner clod in
    both the toner transport sections at the cleaner unit).
    (2) Is the new toner transport motor disconnected?
    (3) Check if the connector of the LGC board and connector Pins are not disconnected.
    (4) Replace the new toner transport motor.
    (5) Replace the LGC board.
    BR
    I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
    • Mr Spock
      Vulcan Inventor of Death
      • Aug 2006
      • 2064
      Also check the harness to the motor. I have had the harness break inside and you could not tell.
      • ToshibaTech
        • Apr 2007
        • 580
        Make sure your developer unit is turning, if it is not then the toner will just pack up. Input gear on the DV unit is prone to wallowing out. If it has a lot of copies on the DV unit they usually start wearing out seals/bearings, etc and just generally need an overhaul to keep them turning smooth. If it has packed up because of the DV unit then in addition to fixing the DV unit you will still need to check what spock and ivovb mentioned.
        I will not give you service manuals or firmware.
