E-mailing meter readings
  • akd
    • Nov 2009
    • 11
    Hi
    Does anyone know if the es2500c range and es351 range can e-mail meter readings directly to us. If so where is the setup
    AKD
  • ivovb
    • 695
    Yes they can. The procedure is described in service documentation - get it (Top Access Guide).
    BR
    I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
      • 8228
      If you upgrade the Firmware to latest, the Service soft key is displayed under the Admin tab, when you press the User Function Hard key on the copier.
      The Service key will allow you to program your Meter reads and when/ when to send it to via email/ fax.
