IM2330 aka eS232 DRUM???
  • Toner Boy
    • Aug 2007
    • 366
    I cannot verify this machine takes the same drum as its Toshiba counterpart, P-roller / Katun list the drum for Toshiba but not PitBowes/Imagistics. Anybody know the answer? Sometimes the ground pin hole is of a different diameter and I don't want this problem...
  • Meach
    • Nov 2008
    • 128
    A Toshiba es232 drum from Precision Roller is only $13.50
    Cheap experiment to find out if it is compatible.
    • ToshibaTech
      • Apr 2007
      • 580
      Not sure if it helps but Toshiba: 200L, 230, 280, 202L, 232, 282, 203L, 233, 283, e16, e20, e160, e200 all take the same drum (OD-1600) Don't misplace the bushing at the rear/geared end of the drum.
      I will not give you service manuals or firmware.
      • Toner Boy
        • Aug 2007
        • 366
        Thanks for your posts, I checked eBay and scrounged up the OEM Oce drum (487-1) for $36 including shipping. I think there may be a difference, probably w/the bushing or something. Hopefully it doesn't take 3 weeks to show up.
