e230 problem
  • esam ramadan
    • 199
    e230 problem
    i have Toshiba e230 after one copy the panel freezing and ready disappear from the screen l replaced the hhd with new pc hhd but it gives me this message "can not find hd data " and i tried to format it but i can't inter 08 what can i do to solve this problem.thanks a lot for any help
  • Hansen88
    • 1076
    I have a 282 with same problem. Havnt found the answer yet myself.
    • ivovb
      • 695
      There is a procedure for replacing HDD. One of the very importance step is installing HDD and UI firmware. Practically it is better to flash all firmwares.
      BR
      I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
      • Mr Spock
        Vulcan Inventor of Death
        • Aug 2006
        • 2064
        You need to follow these steps.
        replace hard drive
        clear & 3 option 3
        flash firmware
        08-947
        08-690-2
        power off then on and check operation.
        The firmware has to be flashed after replacement because that is where the boot information is for the machine.
        • me_the_noob
          • Jan 2011
          • 21
          hi,
          Have you formated the original HDD before you decided to chage it with a new one? If not, try to reinstal the original HDD and format it (procedure: enter service mode (hold 0 and 8 and start the machine) enter 690 set value "2", reboot).
          • esam ramadan
            • 199
            thanks alot for your for your replies
            • esam ramadan
              • 199
              Originally posted by me_the_noob
              hi,
              i did it many times but nothing changed
              • emujo
                • Jun 2009
                • 3009
                You're in over your head..how much money are you saving by doing it youreslf? Not much if the MFP is down for who knows how long. Maybe next time you might ask what is involved in replacing the HDD before you just throw a "HDD from PC" into it and hope for the best. If I was the tech you will wind up calling I'd charge you double hoping to teach you a much needed lesson. Now we're all gonna have to see your posts saying "now what, now what, that didn't work etc". Ok I'm done. Emujo
                • ameritech
                  • 96
                  I had the same problem with my e-280, must change the hard drive and update firmware. PM me if you need it. Best regards
                  • esam ramadan
                    • 199
                    don't judge for thing you don't know it obviously smart guy . that's first lesson to you understood?
                    • emujo
                      • Jun 2009
                      • 3009
                      Atually, no, I don't understand. Emujo
                      • WOETC
                        Mr Spock gives sound advice. If you dont partition the HDD in Clear 3 mode, nothing will work. Then you flash the Firmware in 4-9 mode and follow the rest of his advice.
                        • mine
                          hi am facing the same plm................first u replace the Brand new HDD. replace the HDD by the procedure. create partitions using 3 and clear key switch it on, press 3. format the hdd using 08-690-2. update the firmware. after update apply o8-693,08-947 and restart the mc. mc will work try it...................
                          • esam ramadan
                            • 199
                            i reload the firmware and it worked but i still have the same problem
                            • ToshibaTech
                              • Apr 2007
                              • 580
                              If you are back to the freezing and ready disappearing state then I'd try a System board next. Not a cheap/easy thing to just "try" though. You could also try reseating/replacing the memory and NVRAM chips on the system and logic board along with all other connectors. Usually the old "reseat" the connectors tip doesn't work but every now and then you get lucky.
                              I will not give you service manuals or firmware.
