Toshiba TF 631 copier/fax
  • cmoney12051
    • Aug 2025
    [Jamming] Toshiba TF 631 copier/fax
    I got this copier from a local hospital that is upgrading all their systems and was getting rid of the old stuff. So anyway this machine looks fine on the outside and starts up no problem. But whenever I try and make a copy it starts going crazy. It clicks and clicks and clicks so loud. And it wont stop untill I turn it off. Sounds like a jam but I haven't messed with it much. Any ideas what it could be? Any help is appreciated.
    Sent from my DROIDX using Tapatalk
  • Gregg
    Its fax, and a old one at that. The noise is the probably the feed solenoid. throw it out, parts are few and far between and that thing is expensive as hell to run.
    • cmoney12051
      Well I have a second one but it dosent even turn on. What is the feed solenoid? Perhaps I can switch parts?
