toshiba e-studio 352 toner clicking noise
  • randy13
    • Aug 2025
    I work on mostly Konica Minoltas
    Heres one of my problems
    hey guys ive got a toshiba e-studio-352 that was making a click noise when adding toner. ive replaced all the the toner hopper gears drive belt motor and bottle grab section. everything was good for a week now its back. got lite copies so replaced dev drum and blade went into simulation to turn on toner drive and bottle spins freely. but now customer says noise is back and copies are lite. any ideas or help on this ? thanks in advance jr
  • ToshibaTech
    • Apr 2007
    • 580
    Sometimes the gearing on the DV unit will go bad and make a noise, usually you will get the noise and then blank copies though not an on going symptom like that...
    I will not give you service manuals or firmware.
    • thejack
      • Jan 2011
      • 35
      ya check again main DRIVE Gears and Dev tank Gears, toner hoper Gears . any one creating noise problem.
      Thanks ,
      • JustManuals
        • Jan 2006
        • 9838
        Just Manuals | The Internet's largest collection of manuals | Instant Downloads - Just Manuals | The Internet's largest collection of manuals | Instant Downloads
        Paul@justmanuals.com
        • michaelc
          Field Tech
          • Mar 2011
          • 590
          Check the dev drive gear on the main drive unit. They can crack sometimes and the flat where the shaft sits in will allow the shaft to move freely to without turning the dev unit itself. Hope that helps
          It didn't say that I couldn't do it in the manual.
