Hello everyone, i got an "error code C 21" on my e-studio 207 , i need help how to come out this issue and resolve it.
Error code c 21
[C21] CIS unit initialization error
Does the CIS case move to its home position when the power is turned ON?
llllllllll
YES 1) Check if the CIS home position sensor is installed properly.
2) Check if any of the connectors is disconnected from the CIS home
position sensor.
3) Check if the connector CN14 on the MAIN board is disconnected.
4) Check if the connector pins are disconnected and the harnesses are
open circuited.
5) Check if the conductor patterns on the MAIN board are short circuited
or open circuited.
6) Replace the CIS home position sensor.
7) Replace the MAIN board.
NO
Is there any abnormal sound when the CIS case is moving?
llllll
YES 1) Check if the CIS unit drive belt-1 or the CIS unit drive belt-2 is damaged.
2) Check if the belt tension of the CIS unit drive belt-1 or the CIS unit
drive belt-2 is loose.
3) Check if the joint of the belt stopper and the CIS unit drive belt-1 is
loose.
NO
1) Check if the tension of the CIS unit drive belt-1 or the CIS unit drive belt-2 is too tight.
2) Check if any of the connectors of the scan motor is disconnected.
3) Check if the connector CN18 on the MAIN board is disconnected.
4) Check if the connector pins are disconnected and the harnesses are open circuited.
5) Check if the conductor patterns on the MAIN board are short circuited or open circuited.
6) Replace the scan motor.
