I have a toshiba 2060 running very lite I suspect the developer has went bad I dont have much experience on toshiba not sure of the routines that need to be ran after developer change can anyone help me out with the procedures or where I could get a service manual Thankz for any help
lite copies
http://www.justmanuals.com . The Service Handbook is also available.
Paul@justmanuals.com -
if the density still isnt right you could adjust 05-1 for manual density then 05-5 for auto (interrupt to save)
CheersComment
power on the machine while pressing 0 & 5. you will see Adj mode on panel then enter 90 and press start it will show a value (default 128) increase the value to 145 then press the interupt button to confirm the value then it will add adequate toner to the developer module power off and on make a copy and post your comment...Comment
Thankz to all for the input mechaine looks pretty good I went Sunday and done a pm drum developer wires the whole nine yards step by step from the manule looks good nowSteve Baker
hachet1_12@outlook.comComment
