Toshiba e studio 3500c can't receive faxes
  • gitana1983
    • Mar 2009
    • 141
    HELLO EVERYONE,,, ALMOST FRIDAY!
    Today my day has been messed up by a Toshiba E Studio 3500C, I can send faxes bur for some reason it doesn't want to receive them, when they attempt to send me a fax it shows "communication error" and it never makes it to the Toshiba 3500c.
    Any Idea of what might be causing this? Is there any setting that is blocking the faxes?
    Recently HDD was reseted...
    Any idea will be greatly appreciated.
    Thanks in advance,
  • jonezy999
    just one copy??
    • Feb 2010
    • 952
    Wonder if the machine has incomplete fax to email set up? I would try is a different fax in the same line to narrow it down first. Also do a line folds test to make sure the line isnt too dirty.
    I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
    • Renman
      Did you initallize the FAX and is it on a dsl line?
      • tech07
        • Aug 2008
        • 410
        more often than not, there is a phone line issue. i carry a small plugin phone i bought from target. i unplug the phone cord from the copier and plug in the small phone and then call the fax #. Many times my plugin phone won't ring..the other issue i've seen ( last week), the cord was plugged into the phone port on the copier instead of the LINE port..
        • Mr Spock
          Vulcan Inventor of Death
          • Aug 2006
          • 2064
          I have a phone jack tester that tells whether the lines are correct at the wall. This will not let the machine pick up, but it will send.
          • gitana1983
            • Mar 2009
            • 141
            Thanks everybody for the interest... The machine was faxing fine until we had to do the HDD reset... therefore I don't believe is a problem with the line, I know I mentioned this before but did not specify it as I should... the copier was faxing fine until the reset.
            Any other idea???
