e-35 exit sensors going bad all the time
  • Claudio
    • Feb 2007
    • 235
    The Toshiba photo-interruptors ( PN: C0-03663000 ) on the e-studio 35 fuser exit sensors go bad all the time. The same sensor went bad on an e-studio 550 optical home position.
    Has anyone by some chance tried a different make or part # for a sensor the works and does'nt go bad on a regular basis???
    These Toshiba sensors are a joke.
    Claudio
  • dbrownlee
    • Sep 2005
    • 197
    Don't have any of those machines in the field, but that sensor in the DP 3580/ 2570/ 2460 several times. Never more than once in the same machine, and not in my entire population. (So far, anyway)
    GO TIGERS!!
    • Boogotshot
      • 61
      These sensors were pretty bad about flaking out in the bridge unit also. Toshiba has a new part # for the sensors. The culprit is the heat from the fuser unit. Replace the exit sensors with the new sensors and they should work fine.
      Sorry, I don't have the number handy. I'll try to post it later.
      sigpic No! we never do that with the copier.
      • Boogotshot
        • 61
        Part number for the exit sensors is 4401983230 (SZ-LG248L1) these are the new and improved exit sensors that seem to work better.
        • Claudio
          • Feb 2007
          • 235
          Thanks Boogotshot for your follow-up.
          I think that may be an older part number.
          I have started experimenting with other brand sensors from copiers I took apart that have the green colored PCB inside the sensor to see if they perform any better.
          Have a great week.
          Claudio
