attached is a sample. any ideas? scanner board?20110505090718796.pdf
e studio 45 chopped up copy
Is it fine when you print to it ( if it linked up as a printer). Was the image a scan direct from that machine or copied and scanned via another machine? Is the image a copy from the ADF or from the glass. I noticed in the image some of the solids were not to great and it was skewed slightly.It didn't say that I couldn't do it in the manual. -
Had ths issue years ago..tech replaced every board before we figured it out!.. Tech did a PM and got the transfer and charge wires swapped. Charge wire is a tad bit longer and was causing some arcing. Re-string all wires and make sure they're tight. EmujoIf you don't see your question answered in the forum, please don't think it's OK to PM me for a personal reply...I do not give out firmware and/or manuals.Comment
