Toshiba eStudio 350
  • tcypy1961
    • 773
    Toshiba eStudio 350
    This Toshiba eStudio 350 has 132,000+ copies on it. It has a Time for Maintenance indicator on, and besides changing the developer and corona wires what else would need to be changed at this time?
    The copies are coming out lighter on one side than the other and I was shown a copy job the customer made where the copies progressively got lighter but I could not duplicate this problem. I am thinking the drum may need to be replaced eventhough it appears to be ok.
    Any suggestions and help for these problems is much appreciated, thank you.
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    use the pm kit and then add a drum and maybe a fuser kit. Do not forget to reset the counters and run the dev setup. As to the light copies check the following: drum spacers on the dev unit, the gears on the rear of the dev unit, and the ground spring under the dev unit.
    • Harry
      • 228
      Please clean scannerarea Mirrors and lens first see if it helps
      Reguards Harry
