Misplacing Cyan
  • Toshitec
    MFP Engineer
    • May 2011
    • 22
    [CQ] Misplacing Cyan
    Hello everybody,
    I need your help with a problem on a ES-281C.
    Random it puts all cyan on the wrong place on the copy or print.
    Quality of print is oke it is just wrong placed. (cyan)
    It is exactly 1 cm to low on the print or kopie.
    I checked the d-shaped drive-gear of the tbu, this was tight.
    Now lots of kopies later it seems all right but now an then the problem comes back.
    I can't trace the problem, familiar for someone ??
    Sorry for my bad English, but thanks for your respond.
    John
  • michaelc
    Field Tech
    • Mar 2011
    • 590
    Has the transfer belt unit being cleaned? Clean the reflective strips if you can, if they are worn and peeling away you will need to replace the transfer belt. This might be the cause.
    It didn't say that I couldn't do it in the manual.
    • JustManuals
      • Jan 2006
      • 9919
      Just Manuals | The Internet's largest selection of manuals | Instant Downloads
      Paul@justmanuals.com
      • Toshitec
        MFP Engineer
        • May 2011
        • 22
        Hey Michaelc, thanks for your reply, the sensors that are reading the reflective strips were dirty. I cleaned them and all color prints are perfect so far.
        Thanks again.
        • michaelc
          Field Tech
          • Mar 2011
          • 590
          No probs, glad it worked. I get one right now and again.
