toshiba 452 error code c970
  • atech
    • Aug 2010
    • 89
    [Error Code] toshiba 452 error code c970
    good day... I encountered c970 error in toshiba 452.. I just don't have any Idea about this type of error,need help guys.can it be fixed without changing any parts... thanks a lot.
  • bryand
    • 92
    C970 is caused by the charge wire vibrating. There ware some mods from Toshiba - new end block covers and a heavier spring. You can just bend the brass hanger slightly to put more tension on the wire but you will most likely need to replace the wire and grid as well.
    • JustManuals
      • Jan 2006
      • 9838
      Just Manuals | The Internet's largest selection of manuals | Instant Downloads
      Paul@justmanuals.com
      • michaelc
        Field Tech
        • Mar 2011
        • 590
        I used dampers on the charge wire to stop the vibration, I can get the part number if you need. Also you could try to re wire the charger yourself instead of using the toshiba ones provided in the pm kits. Make sure its the charge wire fitted to, some people fit a trans/sep wire instead.
        It didn't say that I couldn't do it in the manual.
        • CCS
          • 266
          Also if problem persists after working on the primary charge unit and ruling it out, check the contacts at rear frame for the primary corona unit and make sure they are making good contact, bend the alignment tab for proper contact, also tighten the contact screws.
          Check T/S corona unit as well, a broken T/S wire will also throw a C970.
          • WOETC
            make sure all coros and end blocks are clean, and that the wires aren't shorted. If that fails I usually have clear nail varnish in my tool kit. I'll take off the end blocks andinspect them, if there's any discolouration, I varnish the bottom and sides of the block, it provides a further level of insulation and stops shorting through the blocks. It'll last for ages.
            • didi2005
              • May 2011
              • 401
              Need to check the T/S block and Main Charger~~~
