Toshiba E-Studio 520 Update Failed,Reinstall Firmware.
  • tinnyjay
    • Oct 2009
    • 663
    Hello
    One day Toshiba E-Studio 520 showed error code F070 and i changed the wire between LGC and SYS board but the problem is the same.
    After trying firmware update with USB drive,firmware installing started very good with HDD upgrade,but failed when upgrading Laser and Engine.
    Now when i turn the machine on,it says Firmware Failed,Please reinstall the firmware.
    I dont have another version of firmware and please i really need it (european model).
    my e-mail is : tinnyjay@hotmail.com
    I am ready to exchange all my stuff instead of that firmware.
    Please help me
    "Who loves the roses,must also bear thumbs"
  • michaelc
    Field Tech
    • Mar 2011
    • 590
    The hard drive is attached to they system board and that update fine. Your laser is attached to your logic board, both failed to upgrade. Did your scan logic and system board upgrade ok? What about the paper feed? Could possibly be the logic board failing for some reason.
    It didn't say that I couldn't do it in the manual.
    • tinnyjay
      • Oct 2009
      • 663
      You're right,because Scanner is connected to SYS board and upgrade is ok.
      • michaelc
        Field Tech
        • Mar 2011
        • 590
        glad i could help.
