I think he's a little gun shy now...we'll just have to wait until he breaks another machine...any bets on less then 6 weeks? Emujo
Todhiba e studi 520 FIRMWARE FAILED
i have formatted in fat 32 and used 256 mb usb stick.
emujo you are very stupid by the way.
you just judge people i think you should help someone.....Comment
yes of course
i have formatted firstly as the service manual says and than i made firmware.
first i made firmware to the machine only the LSR and engine firmware said error the hdd and the rest it succeed making firmwareComment
Yes i thought so but when i tried three to four times noisy the machine does not boot, when i switch the machine the display stays off and only the scanner lamp stays on all the timeComment
You should call a quaiified technician to fix the problems you have (if that is possible) as it clearly shows from your posts that you are unqualified.
