toshiba 4570 giving error code C41, i tried to reset it, but no avail, checked heater lamp, thermistors and thermofuse, all are ok, checked the wiring its fine, what could be the prob, plz help,thanks in adavance.
toshiba 4570
This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from http://www.justmanuals.com
Paul@justmanuals.com
Re: toshiba 4570
What the heck is a control power cord? Some of the C45X codes require the front door to be open when you reset the fuser code. Also look inside the fuser/adu rear frame connectors for paper dust build up. EmujoIf you don't see your question answered in the forum, please don't think it's OK to PM me for a personal reply...I do not give out firmware and/or manuals.Comment
Re: toshiba 4570
It's already been mentioned but to be more specific, Check the blue connector on the rear of the fuser. A couple of the pins on there are known to fail causing this problem. Sometimes you can repair it by reseating.Comment
ESTANISLAOWENENTON
