e-165 firm ware
  • sjinachandran
    • Aug 2025
    e-165 firm ware
    Dear friends,
    i try to install the firm ware in e-165, i inserted the programe through pendrive with network card and started the machine with '49' it shows firm ware messags, but it keep on standstill no change.
    Any other things needs to be checked pl inform me.
  • michaelc
    Field Tech
    • Mar 2011
    • 590
    Re: e-165 firm ware
    I am sure I used jigs to update that type of machine last time. What size usb pen are you using? Did you format it before using it?
    It didn't say that I couldn't do it in the manual.
    • sjinachandran
      Re: e-165 firm ware
      Tku for reply friend, i used 2GB pendrive and also made FAT formet before use.
      • michaelc
        Field Tech
        • Mar 2011
        • 590
        Re: e-165 firm ware
        I use and gaurd my 256mb and 512mb usb pens with my life. They work on anything. Does your 2gb usb pen work ok on other ES165 machines?
        Why are you upgrading the firmware?
        • sjinachandran
          Re: e-165 firm ware
          i am not try with any other machines, due to lightining both logic pcb and network board bournedout, so i replaced the logic pcb(motherboard) and network board, now the machine works fine without network board, when i connect with network board the machine shows only "please wait" message. i unable to solve the problum, even i changed another network board and logic pcb but no result.
          • michaelc
            Field Tech
            • Mar 2011
            • 590
            Re: e-165 firm ware
            Have you tried to reset the nic? Its 08-693
