C970 but i change the hvt
  • omns23
    • Aug 2025
    [Error Code] C970 but i change the hvt
    ANYBODY HAVE A IDEA FOR THIS PROBLEM
    I CHANGE THE HVT CHECK THE DV BIAS CHECK THE MC CONNECTORS AND CHECK THE NEEDLES AND EVERYTHING IS OK BUT THE MACHINE STILL PUT THE C970 CODE WHEN IS FINISHING A COPY AND ONLY MAKE 1 COPY AND THE ERROR APPEARS AND I CHANGE THE CORONAS AND MAKE 4 BLACK COPIES AND THE MACHINE STOP AND GIVE THE SAME ERROR C970 ...
    HELP ME PLEASE
  • JustManuals
    • Jan 2006
    • 9838
    Re: C970 but i change the hvt
    Do you think posting the model number may help?
    • omns23
      the model is eStudio 233
      • Harry
        • 228
        Remove the needle cleaner assy and try without this shit somtimes is arcing there the copier works without this things!
        Good luck harry
        • JustManuals
          • Jan 2006
          • 9838
          This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
          Paul@justmanuals.com
          • toshibadale
            • Apr 2007
            • 117
            So if I read this right, you had a c970 and the first thing you did was change the HVT?
            As posted in several threads with this problem, check the blocks, restring the transfer-seperation corona wires and main charger wire with Katun wire off the spool, and the problem will likely go away. Do not use prestrung wires!
            • mine
              Dear
              reaplace the main charger unit the problem will be arrest dont change blocks, corona seperately. best of luck.
              • Mr Spock
                Vulcan Inventor of Death
                • Aug 2006
                • 2064
                I have stopped responding to these as I have posted this since the 230 and 350 series.... At least 3 years now....
