Network Config e-studio 182
  • gutillo
    • Jun 2025
    [Misc] Network Config e-studio 182
    Hi. I try ti set IP, mask and default gateway in a Toshiba e-studio 182, but every time I check, the values I set are gone, replaced by others set by the machine. How can i config the network settings and fix them in this machine?
  • sdrawkcab
    Confused & Bewildered
    • Jun 2009
    • 317
    Re: Network Config e-studio 182
    By default the copier is set to dynamic, so set to static, set the IP, Subnet and GW, THEN, go back a screen and press Complete, then the copier will re initialise.
    Some days, it's just not worth chewing through the restraints
    • Travis06
      Tech.
      • 193
      Like the post above said, make sure you hit complete after you set it. Got me before.
        • 8143
        This procedure gets most people the first time.
        • gutillo
          Thanks a lot! It worked perfectly.
