Thermistors scratching e355 UFR
  • arnh79
    • 468
    Anybody else seeing thermistors taking out UFR's on e355 series? We've had a few get badly scratched around 100k, PM says should be good to 200k. It reminds me of the issues we had with e3511 before they modified the thermistors. The gouges are definitely from the thermistors, not the claws. It's frustrating because the rest of the UFR is perfect- probably good for at least another 1ook.
    Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
  • michaelc
    Field Tech
    • Mar 2011
    • 590
    Re: Thermistors scratching e355 UFR
    Maybe try adjusting the thermistor slightly so there is less pressure against the roller. I have not had many problems with this. Most the ufrs do more than they are supposed to. I am sure there is a modified frame for that machine to, something to do with the thermistors. I think the new version of this machine is out in november.
    It didn't say that I couldn't do it in the manual.
    • vincent64
      • 382
      Not sure how old this is, but there are some newer thermistors, the ones for the 356, 456 are being used now, its a updated thermistor for the 355, 455, I was having a prob of the fuser rollers melting to each other, well, lower rollers fusing to the upper one, new thermistors solved it, and that trick of the ground term on the rear of the fuser unit, the 356, 456 have the mods already.
      • sagar4
        • Dec 2012
        • 127
        This is common on this model but there is a modification on this problem and I can't remember what the modification was about. But see if you can find the service bullentin on this model as there is a whole bunch of them. More then any other Toshiba model ever made.
        "Broken again"
        • Travis06
          Tech.
          • 193
          There are new style Therms for the e355 and 455. Also the heat roller has changed from the PISS yellow to a POO brown color. (i.e. new coating) Sorry best description.
