What is the serial port used for on the e-studio 35?
  • yannisp
    • Aug 2025
    Can it be used for printing by connecting to a computer?
    Can someone please shed some light on this?
    Peter
  • wagon
    Village Idiot
    • Dec 2006
    • 654
    Unlikely, although I am no Toshiba authority. Most likely it is there for upgrading firmware and such.
    If you are hitting your head up against a wall it always feels better when you stop.
    • Mr Spock
      Vulcan Inventor of Death
      • Aug 2006
      • 2064
      For connecting a mouse to it. This is for when you need to access the controller directly.
      • yannisp
        Thanks for the replies guys but some advice needed...
        Which controller might that be for the serial port? This machine has no additional cards installed that are obvious.
        I'm in a middle of a dilema though.
        I have purchased two e-studios (one for me and one for my friend)
        - One is an e-studio 25 with the 1031 controller installed and fax and also has a sorter installed.
        - The other is the e-studio 35 with a finisher but no controllers, fax etc
        The dilema is:
        I really like the e-studio 35 because of the touch screen as it seems more user friendly.
        But the e-studio 25 is decked out and can print either over the network or as a stand alone unit, has fax so logic tells me to keep this.
        In you opinion, which is the better unit to keep at the end of the day?
        If I could get a 1010 card for the 35 for a reasonable price (to print over the network)I would choose it in a second but it seems very difficult to get a hold of.
        Both have done about 400K copies.
        What do you guys think?
        Peter
        • nhatthuc0000
          • Dec 2007
          • 44
          You must buy some things
          think i that you need oder some thinks.
          1.GA 1040 card if i want use LPT port
          2.LPT or RJ45 connect cable
          or
          1. GL 1010 controller
          2. HHD installed os included scan
          3.RJ45 connect cable
          i think That will cost you another 200 $ to hit the mark
          good luck
          Good luck to you!
          • yannisp
            Whis is the cheapest option to be able to print over the network on the...
            e-studio 35?
            Which is the cheapest option the 1040 or the 1010? (not interested in fax but do like the scan option though either to e-mail or network)
            I finally got a hold of the gl-1010 hardware service manual and had a good look at it.
            Essentially a computer box with the bridge board to interface with the e-studio 35 and the CPU card that hooks up to the bridge board.
            Initial thought was to just get a computer and hook it up to the e-35 to do the job but the bridge board stuffs things up.
            If there was a way to connect the computer to the e-35 without the bridge board this can be done as cheap as anything and with infinite expandability.
            Is the 1040 setup the same as the 1010 or is it just a stand alone card that plugs into the e-35?
            I'm trying to get as much knowledge as possible about the expandability options on the e-35 to be able to choose which photocopier is the better value at the end of the day (plain e-35 with nice user interface or decked out e-25)
            By the way, I'm also located in Australia
            Peter
            or
            good luck
            • MUMMIM
              • Jan 2008
              • 125
              how do i send to you
              gl-1010 can scan
              ga-1040 can't scan
              I had some gl 1010, fax card, and ga104
              0 it is secondhand of goods and runing very good. I live in Vietnam, how many gl1010 do you interested?
              Descriptions
              HDD : 40-80GB
              SDram : 128MB
              the OS version can print and scan.
              price
              gl1010 is 120USD
              ga1040 is 90USD
              gd 1090-1080 is 60USD
              FOB vietnam
              Originally posted by yannisp
              e-studio 35?
              Peter
              • yannisp
                MUMMIM, PM has been sent to you
                I'm interested in the 1040 for now.
                Peter
                Originally posted by MUMMIM
                gl-1010 can scan
                ga-1040 can't scan
                Descriptions
                HDD : 40-80GB
                SDram : 128MB
                price
                gl1010 is 120USD
                ga1040 is 90USD
                FOB vietnam
                • MUMMIM
                  • Jan 2008
                  • 125
                  how many?
                  How many GA-1040 would you like?
                  mail to me : trieuphongvnn@gmail.com
                  thanks
                  regards
                  Peter
                  • tech1224
                    that is for connecting a laptop to the machine when using FSMS. to udate firemware, set 08 & 05 codes. But it cannot be printed to. (And I have never heard of connecting a mouse to that. for the controler)
