Toshiba Estudio 207 Broken Registration
  • Naveed Shahid
    • May 2008
    • 162
    Hello Every One,
    I am facing problem in Toshiba e studio 207 Broken Registration error message appear
    i am here in bahrain
    i try to do 02 44 but same i dont know whats is the region code of bahrain
    plz repply
    waiting ur response
    naveed
  • JustManuals
    • Jan 2006
    • 9838
    Re: Toshiba Estudio 207 Broken Registration
    The Service Handbook is also available.
    Paul@justmanuals.com
    • UBIK
      • Jun 2011
      • 11
      The pwa-f-sram could be removed from the sys.
      Also check the battery (?) of the pwa-f-sram
      • bauer
        • 72
        This error occurs when an error is found on the phonebook data stored in the flash ROM (IC50) on the
        main PWB or the machine is failed to read the phonebook data correctly.
        1. Turn the main switch OFF. Perform the RAM clear ([1] [3] [*] + ON).
        Warning: Before performing the RAM clear, press the [CLEAR/STOP] key to clear the error
        and print out the TELEPHONE NUMBER LIST, FUNCTION LIST, and FUNCTION
        LIST FOR MAINTENANCE.
        2. Set the functions and program the dial numbers according to the list printed out.
        3. If the error persists, replace the main PWA.
        • marn1980
          First, Sorry for my word,Because i am thailand person.
          This case your machine installation FAX board.
          First time,Your must set jumper at the system board then you can use.
          Originally posted by Naveed Shahid
          Hello Every One,
          plz repply
          waiting ur response
          naveed
