E studio 350
  • dickierock
    • 252
    E studio 350
    Hey all.quick one here..
    Is the fuser reset still the same as the old analogue machines? i.e. 1360, mode 89 reset to zero,thanks in advance.
  • bojans
    • 1313
    Re: E studio 350
    Do you have code on the machine?
    • bojans
      • 1313
      • dickierock
        • 252
        Re: E studio 350
        Hi Bojans,yeah its c440,fuser error,been a while since I worked on toshiba's,
        So its the usual service mode entry,0+8,then goto mode 400,then set either sub-mode 5,7,or 9 to 0,
        Is this correct?
        Many thanks Bojans
        • bojans
          • 1313
          Re: E studio 350
          Yes that's the procedure
          Turn on machine while holding 0+8, then type in 400...
          • dickierock
            • 252
            Re: E studio 350
            Hi Bojans,
            Just wanted to say thanks,the reset worked a treat,
            • bojans
              • 1313
              Re: E studio 350
              You're welcome
