e-studio 35 developer setup
  • micktill
    • Jan 2008
    • 32
    anyone know how to calibrate the toner sensor on the e-studio 35 after a dev change
  • just a tech
    • Jan 2007
    • 332
    believe it's 05-200...after a couple of minutes values will start changing..set range is 235-245.. good luck
    • micktill
      • Jan 2008
      • 32
      Much abliged for that info,thanks you say range is between 235-245 do you have to set it by pressing pressing print or pause or something?
      • just a tech
        • Jan 2007
        • 332
        press "up" or "down" icon to adjust if not in range..press "set" when value is where ya want it..
        • jawir
          • Aug 2007
          • 107
          You also can use 6+Start+power On (PM Support mode) after on the control panel Display K letter, choose 1 to adjust the toner and developer material.
          thanks
          • micktill
            • Jan 2008
            • 32
            Handy to know I,ll try that
            • etsmultan
              • Apr 2007
              • 131
              do hv done tht?it is very simple!
              • mckinley
                Chief Twiddler
                • Dec 2006
                • 150
                Originally posted by jawir
                thanks
                an e-studio 35 doesn't have pm support mode , that's on the later machines such as e350.
                Happiness Is The Road.
                • jawir
                  • Aug 2007
                  • 107
                  Yes I know, that PM support mode is only for eBridge generations. I preferred call this because it's easy say and it's same way in eS350/450.
                  regards
