Toshiba e-355 e-mail and fax issue
  • Moots30
    • Sep 2010
    • 14
    The issue is that when scanning or faxing from an e-355 to groups the client is getting the message "no from address registered". If scanning to individual emails it works just fine. I have created two separate groups. One with fax only and the other with email. They are now scanning and faxing separately, however when someone has both a fax and email programmed under their name it again says "no from address".
    Anyone seen this or have a solution?
  • mckinley
    Chief Twiddler
    • Dec 2006
    • 150
    Re: Toshiba e-355 e-mail and fax issue
    Do you have a 'from' email address configured in top access?
    Happiness Is The Road.
    • Moots30
      • Sep 2010
      • 14
      Yep, From Address is set up in Top Access. It will email if just sending to a one off or someone that is programmed in address book.
      • TheOwl
        • Nov 2008
        • 1732
        Are you trying to use Internet Faxing or are you selecting Fax when trying to do the scan?
          • 8227
          In TopAccess you have to program both the email and internet fax tab identically.
          • Moots30
            • Sep 2010
            • 14
            Not using internet faxing at all and pressing the scan hard button when scanning to the group.
              • 8227
              I understand but program both email and ifax tabs identically. Otherwise your address book will screw up and create error message.
              • Moots30
                • Sep 2010
                • 14
                Thanks I will give it a try.
                • Moots30
                  • Sep 2010
                  • 14
                  Still a no go even after making the email and i-fax tabs identical in Top Access. Any other suggestions?
