E-studio 160 message
  • ogye
    • Aug 2025
    Hi, does anyone know how to get rid of maintenance/drum message? Imaging unit was replaced.
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    08-673 set but ONLY if you actually replace the parts required.
    • elcondor
      before enter code 0+8 673 then 0+8 340 code 27000 to enter 0 and press set.. no more again a sign
      • tech1224
        hit your program key then *#** then go to test mode, maintance, and the memory rewrite. enter E25762. us # 4 to make the E. then hit set. then enter 00. it will then go to E25763 enter 00 again. repeat until it gets to E25766. I am pulling all of this straight from memmory but I beliave it is correct I will check it out when I get to work tomorrow.
        • ogye
          Thank You All
          Thank you all for the replies, It worked fine. Since I did replace the process unit (imaging unit?), I just wanted the message "maintenance/drum" to disappear. Thank you all for your help.
          • elcondor
            08 251 you must clear change to "0" this code
