USB 2.0 cable
  • nıke-reebook
    • 50
    USB 2.0 cable
    Whatshould I do ifmy computerdoes not recognizethe USB2.0 cable
  • Hansoon
    • Sep 2007
    • 3391
    Re: USB 2.0 cable
    First thing would be to try another cable. USB cables fail more often than one thinks.
    Hans
    • emujo
      • Jun 2009
      • 3009
      Re: USB 2.0 cable
      If it's a B&W toshiba, then without the enabler (print, scan or print/scan combo) it will not print. If you have an enabler installed, but the wrong one, it won't print. Once you plug the USB into the MFP and your PC, you should get a message to install software. The driver is on the CD included with the MFP. Emujo
      • nıke-reebook
        • 50
        Re: USB 2.0 cable
        Thank youfor your interest
        • emujo
          • Jun 2009
          • 3009
          Re: USB 2.0 cable
          Also, the USB cable is standard, the slot you plug it in to determines weather it's USB 1.0 or 2.0. You never actually said you were trying to hook up a copier to the cable. Emujo
          • michaelc
            Field Tech
            • Mar 2011
            • 590
            Re: USB 2.0 cable
            well spotted emujo.
            It didn't say that I couldn't do it in the manual.
