dp 6570
  • cpress1
    • Aug 2025
    dp 6570
    Hi - I need some help on a DP 6570. I was running single sided had a jam - cleared the jam got message for lct add paper. It has paper. Turned machine off and back on still shows add paper. Machine is warmed up but will not let me print or change to paper drawers. Checked all fuses and all are good. Paper tray on lct will not go up or down. Help please. Thanks Vince
  • michaelc
    Field Tech
    • Mar 2011
    • 590
    Re: dp 6570
    Check to make sure no paper is behind the cassettes/LCF and also in the feed units.
    It didn't say that I couldn't do it in the manual.
    • cpress1
      Re: dp 6570
      NOthing anywhere. Thanks for the response. I just turned it on again and it warmed up but still the same problem.
      • JustManuals
        • Jan 2006
        • 9838
        Re: dp 6570
        Paul@justmanuals.com
        • emujo
          • Jun 2009
          • 3009
          Re: dp 6570
          Old box, but if memory serves....there was a setting in 05 (or 08) that went to 1 when LCT had problem. Setting back to 0 cleared and LCT was available again. 2nd, disconnect finisher and try again if success, then you have a tray lift motor causing a logic error. Replacing the motor solved this one. Emujo
          • cpress1
            Re: dp 6570
            Thanks for the info. The code is 08-382 and I ran the code and it was at 0 - reset it back to 0 again and nothing has changed. Thanks
            • copyplus
              • Jul 2009
              • 100
              Re: dp 6570
              I have same problem with my estudio 80. Actually the problem started due to my stupidity. While the paper tray was up I did put a package under it and when the paper emptied it started going down and due to that package it got stuck. I turned the machine off, took that package out and turned the machine on and guess what, the problem. The lct is not going up or down. The add paper is flickering on the display even if there is paper. The lct door switch is off. Sometime the display shows there is paper in the tray but when you push the lct door switch it starts flickering. Called the mechanic who spent 4 hours and did not find anything and while leaving told me that the main logic board needs to be replaced. The guy did not even checked voltage at any point. Would you kindly suggest how the problem can be solved? Machine has only 300k copies on it. Are there any points where we can check the voltage? How may voltage should be at the tray motor? Any possible suggestion would be appreciated. The manual paper feed is working and all the other trays are working fine. thanks
