How to Activate Toshiba e-Studio 305 Printer?
  • relation
    • Sep 2025
    Condition:
    We have a Toshiba e-Studio 305 multifunctional copier in our office; It has a network card and when I connected the device to the local network the printer was detected and installed on the computer using the provided drivers; However the machine does not accept and perform print orders; Also the Print button on the machine's panel does not turn on when I press it (only a beep sound is heard, like the one when you change to Copy and e-filing).
    Questions:
    1. How can I enable the Print function on this device?
    2. Is there any hack or patched firmware for it?
    3. I know that there is some sort of usb dongle that enables print/scan function, is there any way that I could create such a dongle using ordinary USB memory sticks?
  • ss12
    • Jul 2008
    • 289
    There is a code to allow printing in 08 mode,however this is a trial function which only lasts 60 days after which you have to purchase the printer or printer/scanner dongle. No way around it I'm afraid.
    • jonezy999
      just one copy??
      • Feb 2010
      • 952
      Re: How to Activate Toshiba e-Studio 305 Printer?
      I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
      • bauer
        • 72
        The e/s 305 does not require a dongle, print and scan are standard in North America.
        Have you setup the IP address?
        • Tec1
          • Dec 2011
          • 48
          can you ping it?
          • relation
            1. Yes, I could ping the device IP and even I entered the IP in the browser and accessed its control panel through the web interface.
            2. Where can I get that trial version and how is the process; who has made this trial, and can anybody possibly hack the code to give full access to what we have already bought! (this is really Defective by Design!)
            • fourl6
              • Nov 2008
              • 94
              Not standard in Australia
              • relation
                Is there anywhere you can find these devices' Service Manuals for free?
                  • 8333
                  Depending on the Country you are located, the Print/Scan functionality may or may not be included in the the copier.
                  If not included neither it nor the Service Manuals are free.
                  This is a not uncommon design philosophy for many products. The feature is embedded in the product but you must purchase a software Key to unlock the functionality. There is no "Hack" to unlock Print/Scan, you must have a physical proprietary Toshiba Print/Scan USB key in the copier for the feature to become enabled.
