Fax Not Connecting on a 451c
  • not_a_copier_tech
    • Aug 2025
    Hello,
    I just purchased and "installed" an off-lease 451c that had a fax board (GD-1200) installed just prior to me picking it up. However, the fax board refuses to "connect" in that it doesn't seem to communicate besides picking up an incoming call. If I call the fax number, it rings twice before the machine presumably picks it up, but the line is dead silent afterwards. When trying to send a fax, the LED lights up for a matter of seconds and I don't hear anything through the speaker. It errors out with a status of "0050".
    I've followed every procedure I can find online, including reinitializing the fax board. The symptoms persist despite any changes I make. I did notice that the existing fax line is split with the DSL through a filter. Could this possibly be the cause?
    Thank you for your help, let me know if you need more info.
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Re: Fax Not Connecting on a 451c
    need dsl filter for fax line. (dsl configuration is not supported)
    check the phone line polarity is correct
    replace the ncu pwb in fax unit.
    • not_a_copier_tech
      Thank you for the advice.
      Would the fact that the DSL modem is connected to the same filter cause any problems? I remember reading a note somewhere in one of the manuals that "parallel lines" or something will cause issues.
