toshiba studio 3500c with MR 3018 E724 error
  • pcernicky
    • Feb 2010
    • 66
    HI,
    When machine on, it goes to E724 error code mode.
    When in diag 03-[FAX]ON/[7]/ all sensors are functioning. replace read sensor and registration sensors all 3 of them.
    Thank you.
  • JustManuals
    • Jan 2006
    • 9838
    Re: toshiba studio 3500c with MR 3018 E724 error
    Paul@justmanuals.com
    • Mr Spock
      Vulcan Inventor of Death
      • Aug 2006
      • 2064
      If you replaced all three "ruby" sensors then replace the adf pwb. Especially if you did not turn power off when replacing.
      • pcernicky
        • Feb 2010
        • 66
        So it ended up to be the 4th registration sensor. All is working fine now.
        Thank you.
          • 23010
          Similar machine, same solution. Mine was a eS3540 with the MR3022 document feeder.
          The interesting part was that I could feed a hundred originals with no problem. Then while I was looking up the E724 and E712 (both point to the original registration sensor S5) the error popped up. I wasn't scanning or copying anything. I was just standing there, and it went into an E724 and it wouldn't clear. Re-boot the MFP and it clears and will do a hundred more originals. This happened four times. Each time I thought I was close to leaving it would error out again. ("Will you please stop that!")
          Like the other Sharp 73 photointerrupters it was completely unpredictable. Each time I tested it in the service mode, all the sensors changed state correctly, but when I put my meter on CN74 pins 1, 2, 3 it didn't show the change. Bizarre.
          Did I mention that Toshiba manuals suck? Nearly every other manufacturer has a two dimensional or three dimensional diagram of Location of Electrical Components. The best I could find was an illustration of replacing sensor S5. For me the clue was seeing three sensors in a row in the illustration. =^..^=
