Toshiba E-studio 450 scan file storage error
+ More Options
Posts
  • Will
    • Jun 2007
    • 171
    Have a Toshiba E-450 that intermittently when scanning to its hard drive, a file storage error comes up and when you check job status it shows it didn't go thru. Doesn't seem to matter if its 1 or 2 pages or if its 30-40 pages. Any suggestions on what to check or do. When it works it works fine with no problem.
  • emujo
    • Jun 2009
    • 3009
    Re: Toshiba E-studio 450 scan file storage error
    You need to look at the job log and get the exact error code...but w/o seeing this, I'd say the HDD may be failing,,not unusual as this MFP has been around for some time. Firmware update might be helpful...you can also do a HDD check via service mode to look for bad sectors. Emujo
    • blaze2000
      • Sep 2010
      • 232
      HDD failing I've also seen quite simply the HDD getting full. Check to make sure the file deletion time is frequent enough to keep lots o' storage space.
      • dherring
        • Mar 2012
        • 7
        I agree that you need to check the current firmware version. I would also backup templates, address book and network settings then do an 08-690 to reformat the HDD. If the HDD hasn't been replaced before then replace it with a new one like WD. If the current HDD is a Maxtor then I would definitly replace it.
