es 203sd printing problem
  • patwilf
    Service Technician
    • Nov 2009
    • 41
    [CQ] es 203sd printing problem
    Installed one of these at the customers Site a year ago. It has the network expansion kit installed. But we can't figure out how to obtain the ip address. Toshiba said it was inside the box that it came in. We no longer have that box. How do we get the address now????
  • patwilf
    Service Technician
    • Nov 2009
    • 41
    Any thoughts
    • Harry
      • 228
      Re: es 203sd printing problem
      there was an utility with the network kit GA 1330 please contact your toshiba center for a copy of this.
      otherwise try ipconfig-all in networkcomputer and frigle out with your browser to find the ip from mfp.
      good luck harry
      • TheOwl
        • Nov 2008
        • 1732
        Print out a Network Configuration page, it will be on there.
        Why don't you just set the IP address to static (manual) address? Then you will know what the IP address is.
        Also, if you are after the MAC address and not the IP address, then print out the Network Configurate page.
