es-901 false waste toner full messages
  • blaze2000
    • Sep 2010
    • 232
    been fighring this for a month or two... a clients machine randomly shows waste toner as full when its not. we clean entire system and replaced torque limiter... aby thoughts? thanks
  • JustManuals
    • Jan 2006
    • 9838
    Re: es-901 false waste toner full messages
    Paul@justmanuals.com
    • tech07
      • Aug 2008
      • 409
      I've seen this for sure...could be a bad sensor, but WAY more likely is the sensors are dirty.There are 2 to clean..1 where your belt/torque limiter is and another on the rear of copier below toner cartridge sensors..Had 2 901's beside each other for 3 years, each reaching 15 million copies...cleaning these sensors became routine for false waste toner messages. That whole area should stay clean or you'll get those intermittant messages..
      • blaze2000
        • Sep 2010
        • 232
        I'm going to replace them both on my next call. I appreciate the input.
        • tech07
          • Aug 2008
          • 409
          I never had to replace the sensor in 3 years...Just shot them with an easy stream of canned air for a couple of seconds worked every time for me.
          • blaze2000
            • Sep 2010
            • 232
            ok I'll clean em first and see what happens, thanks. Rep added
            • blaze2000
              • Sep 2010
              • 232
              Well, I wound replacing the sensor at the back of the toner unit and she took off like a banshee. Hopefully it did the trick. I did try cleaning it with no avail. Thanks again for the help.
