Toshiba Estudio 600
  • Tim C
    • 167
    Toshiba Estudio 600
    I have a Toshiba e-studio 600 with copy quality issues. I is giving me
    Sparatic wide dark shaded bands from top to bottom of the copy. Happens
    On prints as well as copies, it also a times will squeeze the
    print towards the trailing edge . This happens every 10-15
    copies no Pattern
    thanks for your help
  • emujo
    • Jun 2009
    • 3009
    Re: Toshiba Estudio 600
    Not sure about the top to bottom bands, but lead to trail compession can be caused by the drum drive motor set screw getting loose...drum drive stalls slightly and the image gets written to a smaller space. Emujo
    • Tim C
      • 167
      Thanks for you help. It was the Drum Drive Slipping enough to cause the problem. Now after putting it all back together, It prints and Copies great
      • emujo
        • Jun 2009
        • 3009
        Very good, Im here ( for the most part) to help...Emujo
        • Jaws
          • Oct 2007
          • 236
          Got an e-studio 650 giving me a problem. Kind of sounds like the one above. 1st are 600's close to be 650's, I see they look the same on the outside. Check out my portrait print of the problem.
          • spree
            • Jun 2012
            • 211
            Hello, I have periodical maintenance notification. All life parts are still not in changing cycle (see photos). I want only to clean rollers, mirrors, vaccum it and reset (clear) the periodical maintenance notification. Machine total counter: 766.728 copies. But why PM notification?
            Please could you help, which 0+8 (6+S) to choice and what code and value to set??? (I studied manual, but it is difficult to see, which)? Maybe 0+8 and then 252, than "0" ?
              • 23008
              Take a look in the 08 modes. First check 08-252.
              For each counter, let's say "Web": there are four different 08 modes. There is the page counter, page yield, rotation counter, and rotation yield.
              Especially on older machines like this you'll find that the yield (or any 08 mode) can become corrupt, showing values like 999999999, or 0, or *05*215. The yield or counter just needs to be re-programmed. It's just time consuming finding and checking all those 08 modes. =^..^=
              • spree
                • Jun 2012
                • 211
                I made only clearing of 08 - 252 to "0" and the preventive maintenance message gone away.
