e-Bridge X Issues
  • CJD900
    • Nov 2009
    • 18
    Re: e-Bridge X Issues
    I hate that it has came to this... But I have had a lot of print issues with the EBx machines, try using the print drivers from the previous models. For the es306,es256,es356,es456-use es255-es455 drivers For the es556,es656,es756,es856-use es555-es855 drivers same for the color machines es2040c-es4540c-use 4520c drivers es6550,es6540- use es6530 drivers
      • 8193
      We are experimenting with:
      • Samsung
        • Nov 2012
        • 4
        toshiba has a bullitin on this issue if you have access to fyi check it on that section, basically is the control panel. ribbon cable is rubbing on control panel frame.
        • arnh79
          • 468
          #19
          We haven't gotten that bulletin in Canada yet. Would you mind posting it for me to read?
          Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
          • Samsung
            • Nov 2012
            • 4
            #20
            Overview
            To prevent the machine from unexpectedly shutting down or having other Control Panel related errors, the LCD Bracket has been changed.
            Copier Bulletin: TSB-1236 Rev.01
            Date: 9/12/2012
            Page: 1 of 2
            Models: e-STUDIO4540C Series, e-STUDIO455 Series, e-STUDIO455SE Series, e-STUDIO456 Series
            Subject: Change of Control Panel Bracket to Prevent Ribbon Cable Damage on KEY Board
            Copyright-2012 Toshiba America Business Solutions, Inc. (TABS). This publication contains proprietary and confidential information retained for reference purpose by authorized TABS dealers. Unauthorized use of this information is prohibited. TABS makes no express or implied warranty, including implied warranties of merchantability for a particular purpose, with regard to this technical publication and disclaims any claim arising by reason of the possession or use thereof.
            Detail
            In some cases, the Control Panel Ribbon Cable may rub against the LCD Bracket and cause the machine to unexpectedly shut down or have other Control Panel related errors.
            Note: It is recommended to inspect this area during the next service call on the applicable machines according to the serial numbers listed below.
            The Ribbon Cable may become damaged because it is pressed by the gasket and contacts the edge of the LCD bracket.
            To prevent this from occurring, filament tape has been attached to the edge of the LCD bracket at the factory on machines produced beginning with the following serial numbers:
            e-STUDIO2040C : CJE231920-
            e-STUDIO2540C : CHE231934-
            e-STUDIO3040C : CNE221008-
            e-STUDIO3540C : CQE222841-
            e-STUDIO4540C : CME219663-
            e-STUDIO456 Series: C2E23885
            1*
            0
            Identification of New Part
            Changed/Added Part No. MODEL P-I Before Change After Change
            2040C/2540C/3040C 3540C/4540C 3-48 6LH52221000 BRKT-LCD 6LJ02910000 ASYS-BRKT-LCD-H14X
            205L/255/305/455 37-47A-1
            206L/256/306
            356/456/506
            3-47-1
            • arnh79
              • 468
              #21
              Thank you so much. I'll definitely be looking into this.
              • Greyghost
                #22
                So.....just got our 11th firmware update for ebx.........this one includes reloading drivers.
                That should just about do it I think .
                • NSD
                  • Aug 2011
                  • 44
                  #23
                  Has anyone had further problems with these machines or are they settling down for you?
                  Mash machines seem good, but not as good as the EB3s where
                  the big monos lock up alot.
                  Boradpeask seem OK now
                  and the little monos I would just stay away from.
                  • arnh79
                    • 468
                    #24
                    Ever since v.1600 f/w was released I haven't had any more freezing/lock-up issues. I've got about 30-40 mono EBX machines in the field and they don't give us any problems as long as we upgrade them to v.1600. The "issues fixed" list included with v.1600 contained lots of scenarios where the machine could lock-up and even in newer versions of f/w I see they are still including fixes for locking up.
                    I never ran into any of the weird driver issues some of the guys on this thread were talking about, so I can't say whether or not those issues have been resolved.
