E232 not access 08 mode
  • nhatthuc0000
    • Dec 2007
    • 44
    I did reinstall firmware 3 times and finished, but I not access into 08.
    I changed hdd , can you help me.
    Good luck to you!
  • didi2005
    • May 2011
    • 401
    Re: E232 not access 08 mode
    Did u mean that after finish update the firmware, u not able to perform 08-947?
    • JustManuals
      • Jan 2006
      • 9919
      Paul@justmanuals.com
      • TheOwl
        • Nov 2008
        • 1733
        Did you go through all the items in the Firmware Assist mode such as clearing the NVRAM Flags?
        Was the machine working prior to the firmware update?
        • didi2005
          • May 2011
          • 401
          What is the machine original firmware version & current version?
          • nhatthuc0000
            • Dec 2007
            • 44
            finish update, I can Copy, but nots to perform 08.
            Good luck to you!
            • esam ramadan
              • 199
              may be the problem in the control panel . i saw this problem before in e35 and solved after replaced the panel
              • michaelc
                Field Tech
                • Mar 2011
                • 590
                Use the start + 1 to check the display panel (i think that is the code). I am assuming the display will be working if you can press 4+9 for the firmware update but still worth a check. After a firmware update you need to go straight into the 08 codes. Code 947 then initialise (as didi mentioned). After the firmware update do you or can you access the 08 codes?
                You could try repartitioning the hard drive before the firmware update.
                What was the reason for the firmware update?
                It didn't say that I couldn't do it in the manual.
                • aligis
                  • Jul 2010
                  • 56
                  try to formate hdd.. 08-690 and update firmware
