NOTICE: Users should expect a few periods of downtime this evening while we work on a few updates to the system.
Use the start + 1 to check the display panel (i think that is the code). I am assuming the display will be working if you can press 4+9 for the firmware update but still worth a check. After a firmware update you need to go straight into the 08 codes. Code 947 then initialise (as didi mentioned). After the firmware update do you or can you access the 08 codes?
You could try repartitioning the hard drive before the firmware update.
What was the reason for the firmware update?
It didn't say that I couldn't do it in the manual.
