Toshiba e-stduio 650/720 light copy
  • copiertech
    • Oct 2010
    • 55
    [CQ] Toshiba e-stduio 650/720 light copy
    Hi,
    we are facing tghe following problem light copy in toshiba e-stduio 650/720, any soultion.
    Thanks in advance.
    Waleed
    Copiertech
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Re: Toshiba e-stduio 650/720 light copy
    How many copies on developer?
    have you checked the dev drive gear?
    • didi2005
      • May 2011
      • 401
      Is it happen on copy only or printing as well?
      If copy only, try clean the exposure lamp...
      If copy & print, try clean the slit glass...
      • bryand
        • Jul 2008
        • 92
        Check to see how many copies are on drum/dev
        clean optics, laser slit glass,
        run 05-290 after cleaning
        • michaelc
          Field Tech
          • Mar 2011
          • 590
          There are many things which can cause light/poor copies on these machines. What have you tried so far to fix this problem and as some on has already asked. Is it doing it on copies/and prints or just copies.
          It didn't say that I couldn't do it in the manual.
          • copiertech
            • Oct 2010
            • 55
            Its just the copy or print connection on this machine.
            Waleed
            Waleed
            Copiertech
            • emujo
              • Jun 2009
              • 3009
              Unless you can post something that looks like you have some basic understanding of how a copier works, and what you already done to correct the issue, you should probably not expect too much assistance..If you're looking for step by step instructions on how to pull the glass off and clean the optics this is the wrong forum. Emujo
              • esam ramadan
                • 199
                may be transfer belt is bad
                • copiertech
                  • Oct 2010
                  • 55
                  Thanks guys we did check every thing you recomanded but in the end we did full PM services.
                  Thanks a lot for you kind assist.
                  Waleed
                  Copiertech
